air filter
LaimG
- My Bike: zxr 400 h1
air filter
A simple question, is there any difference between the H and L model panel filters? I want to upgrade and can only find L ones!!
Gotta keep it singing
Re: air filter
A quick check ofthe parts microfiches available HERE will tell you that there is a difference between the H and L model filters..................if you want a new H model air filter best hope for getting one is here
Or if you wish to "upgrade" then a K&N filter is probabaly the most easilly available option.............if you click HERE you will be able to search for and find your local K&N dealer and installer.
If you fit a K&N air filter you will need some dyno time to have your bike properly set up to run ir.
GOOD GOD i MUST BE FEELING WONDERFULLY HELPFULL AND GENEROUS TODAY
GOOD GOD i MUST BE FEELING WONDERFULLY HELPFULL AND GENEROUS TODAY - jake
Re: air filter
to add..
I dont actually think you can get a k and n filter for the H box. I may be wrong. I think there is a pipercross jobbie for the H tho.
Anyhow you are better off paying cradley for a new standard one, 25 quid if i remember, and just as good as any aftermarket panel
Re: air filter
yep your right Jake K&N dont do an air filter for the H
