H2 starting problems
R P Corse
CBT slow
CBT slow
My Bike: ZXR400 H1
Post by R P Corse »
just bought a new battery for my H2, filled up with acid, left it on charge, and then placed back into the back after it had charged... nothing :(
checked the sparkies, i've checked fuel, fuses, bumping, jumping, lights all work, indicators .. everything is fine on the bike,trust me i have checked the WHOLE bike over, it just wont start.
it did this last week with the old battery, but that was dying anyway... so the obvious thing is to go and change it.
any ideas as to what it could be? :(
Re: H2 starting problems
you say you have checked for sparks, have you changed the plugs? leads ok?
R P Corse
CBT slow
CBT slow
My Bike: ZXR400 H1
Post by R P Corse »
i changed the plugs about a month ago, and the bike has only been ridden 3 times since due to it bein off the road - have been fixin her you see.
its sparks fine, they all work as they should.
then i would suggest a fuel problem, have you tried easy start?
R P Corse
CBT slow
CBT slow
My Bike: ZXR400 H1
Post by R P Corse »
no, afriad i havent, what is it? lol
spray it down the carb intakes and it starts every engine (claimed)
R P Corse
CBT slow
CBT slow
My Bike: ZXR400 H1
Post by R P Corse »
right oh, will have to get some tomorrow then :( how much is it?
gona charge the battery over night too, see how that goes.
only about £3-4 a can mate, most places like halfords do it.
R P Corse
CBT slow
CBT slow
My Bike: ZXR400 H1
Post by R P Corse »
ah nice one mate cheers, will pick some up as soon as i can then, will let you know how i get on!
zxr_oli
My Bike: Daytona 675
Post by zxr_oli »
May sound a bit simple, but are you using the choke?
I remember my 50 never needing the choke, the first time i tried starting the ZXR i couldn't get it going, then i realised i was forgetting the choke :P
Is it in gear?
crushedlizard
My Bike: ZXR400 L2
Post by crushedlizard »
Scott221 could be onto something there. When you say it won't start, do you mean the stater turns the engine over but it won't fire? Or do you mean the engine won't even crank ie the starter motor does nothing?
If it's the latter, try starting it with the clutch in and with the side stand up. Check your neutral light - it causes me some hassle sometimes, particularly if I want to warm the bike up on its stand!
I dont know about the H's but the l model's are fitted with a switch that if the bike is in gear, it will not turn over, quick stand up or down. It happend to me during the first few weeks of being OTR and it had me in a bind or about an hour! Check your fuel tap as well.
Tell us exactly whats happening as well, does the starter turn over?
R P Corse
CBT slow
CBT slow
My Bike: ZXR400 H1
Post by R P Corse »
ok well i have tried startin it in neutral (obviously) with the stand up AND down and still wont start - wont tick over.
have tried to bump it aswell and jumping it with leads, neither of them work.
