Hey guys, I am Bart(21) from the Netherlands and I recently purchased a ZXR400 '00 second hand, I did maintenance of the motorcycle (all fluids etc) at a dealership and they found the head gasket was sweating a little bit. But repairing this would set me back to much money so decided to not do anything about it.
When I started riding it I was leaking coolant frequently, and the bike was getting hot a lot.
Few days of riding pasted (1000k's) and now it is making this noise, it started when I came off the highway and downshifted from 6th to second gear.
Anyway I don't really know what to think of this if I have to take the engine out to check if what it is, or if it is an easy fix because sometimes the sound is not there for a few minutes of riding and then all of the sudden it kicks in. It does have power still btw.
video of sound and bike https://youtu.be/1DkTq2UhbeE
Anyway, hope someone recognizes the sound and or the problem and can help me out,
Have a nice Christmas everyone and a happy new year!
Cheers Bart
ZXR noise out
- Miles
- My Bike: ZXR 400 L3
Re: ZXR noise out
Run the bike and look for bubbles in the coolant. A compression test will confirm an issue.
Not certain but I'm sure your missing hoses from the front of the cylinder block. The L9 had extra air hoses I believe that run from a valve at the air box. Can only guess they were for added cooling
- My Bike: ZXR 400 '00
Re: ZXR noise out
Hey man thanks for your reply, I will take a look at that. Anyway made another video where you can hear it clearer. Hope this helps! https://youtu.be/4oRz9Z4Bygg
Re: ZXR noise out
Well, it got fixed, it was the timing chain tensioner. Thanks for the help anyway. Cheers Bart
Re: ZXR noise out
valve clearances need measuring every 6000 miles/10k kms...dont neglect to do this or you will quickly get a very large repair bill when one of your pistons contacts a valve and takes your engine with it...bartez18nl wrote:Well, it got fixed, it was the timing chain tensioner. Thanks for the help anyway. Cheers Bart
JPN ZXR250 A2 (1990) - Revs to 19,200rpm... 'nuff said![:smt003](./images/smilies/003.gif)
Re: ZXR noise out
Thanks you for pointing this out, and yes, valves have been adjusted/checked!banner001 wrote:valve clearances need measuring every 6000 miles/10k kms...dont neglect to do this or you will quickly get a very large repair bill when one of your pistons contacts a valve and takes your engine with it...bartez18nl wrote:Well, it got fixed, it was the timing chain tensioner. Thanks for the help anyway. Cheers Bart
![:smt008](./images/smilies/008.gif)
