Help needed please?.
- My Bike: kawasaki zxr400sp
Hi there folks I need some help in trying to get my zxr400 (1990) running,now its not been started for ages,i have had the carbs cleaned by a motorcycle mechanic,i have fitted new spark plugs,oil and filter,there is a brand new battery on it now when I try and turn it over it wont crank over,it makes a clicking sound which is coming from near or the starter relay now I have changed different things on the bike starter motor,starter relay (it was second hand),and cdi unit so now I have just run out of ideas of what it could be when I try and start it the needle on the rev counter moves to say 6rpm if I try and rev it but it just carries on clicking any help will be much appreciated regards shane.
- My Bike: ZXR400
Re: Help needed please?.
sorry cant really help without being there, but the noise described sounds like a low voltage battery, or knackered starter solenoid.
if your battery voltage is good (min 12.5V) you should be able to srank the starter motor by bridging the two poles on the starter solenoid with something metalic like a screwdriver...make sure its insulated though and you are not touching any metal bits of the bike or the screwdriver, the engine should turn...does it?
Hi there,do you mean connect the starter solenoid motor to the actual starter motor via a screwdriver,thanks again shane.
- Miles
- My Bike: ZXR 400 L3
I think banner means the two poles in the solinoid. Thus bypassing it and sending power directly to the starter motor.
(Put a INSULATED screwdriver across the two terminals that the positive cables bolt to, one from the battery and one goes to the starter)
This will tell you if power and possibly if the starter motor is ok.
like this:
https://www.youtube.com/watch?v=VnbbKIi1h3c
if you get a spark and the motor turns then your solenoid - or the connection to it from the starter switch is dead, if you get no spark and the motor doesnt turn, check that you have continuity between the engine and the -ve battery terminal, from the +ve terminal to the solenoid, and from the solenoid to the starter motor, if all those are fine then you have a dead starter motor.
its an old bike...buy a decent multimeter, you will need it
