1) the bike will not stay on, I turned it on and after about 10 seconds it died, tryed again same thing.
now after trying a couple of times it only manages half a second before cutting out.
2)My oil pressure warning light is not on when the key is in the "on" position.
3)I have a tiny leak from the gear change oil seal.
so...anyone have an ideas why it keeps cutting out?
fuel is on, and I drained the carb bowls and there is petrol in there.
Plugs are clean, Ive tryed with neutral and first gear with clutch in.
choke doesnt help. Im lost.
also the oil pressure switch, how can I check it?
and lastly does anyone know how to replace the seal on the gear change shaft? hopefully without taking the engine apart..
Thank you for any help.
