i had it outside under a cover for a while and would start it occasionally to keep it all ticking over, but i left it for a about a month and now when i start it it sounds very rough although it will run on choke, but when i take the choke off and give it some throttle it just dies,
then i can start it again on choke until i give it revs then it dies again, i took the carbs apart today and cleaned them all out but its still the same,
i work in motorsport making exhausts and although i'm good with fabrication i'm not so good with engines
does this problem sound familiar? i've read a few of the posts on here but nothing exactly the same
any help would be greatly appreciated
