been tinkering but
eddy
- My Bike: 2000 l9 zxr400
been tinkering but
right thought id do some work on the bike and got the head polished and ported and while i was there fitted bigger jets from 95 up to 100 and a pipercross panel filter and been out and the bike is alot better but wen its in 4th 5th and 6th it gets to twelve thousand it seems to start under fueling and dies off instead would it be worth going up 102s instead or is there anything else that this could be
Re: been tinkering but
Not 100% sure but i think the needles start to come in at that engine speed. So an adjustment of needle heights might be whats needed. Best wait for someone who knows exactly before going ahead and trying it.
- jake
how does it feel/sound when it gets there? do you have a good exhaust system on it
have you done anything else?
tk400
- My Bike: ZXR400 , ZXR950
what kind of head work was done. Ie how much material was removed and where. Did you change the comp ratio (deck the head). I personally would get a wide band o2 meter hooked up and see what is going on. Most dyno places have them setup and can log over the entire range and TPS. Then you will know where you are. cheers
Tk400
Tk400
eddy
its got stainless headers with scorpion can on it and it feels as if it sort of cut out or ran out off fuel and not sure how much was took of the head as i didnt do it but it has made a big difference as soon as it gets passed four thousnd it flies but its just in the last few gears its funny
bengone1
- My Bike: 1994 ZXR400
Don't forget. When you deck the head the cams get retarded giving you better top end at the expense on bottom end (exact opposite of advancing timing)
eddy
well its brilliant bottom end but funny top end and alsoforgot to mention advanced the ignition timing a bit aswell
