bike cutting out
Chris1984
- My Bike: zxr 400
bike cutting out
Need some advice lads,i start the bike and it idles for a few mins then it just dies just as it starts to warm up.
Re: bike cutting out
Have you managed to ride it yet?
Does it restart ok?
Does it restart ok?
Chris1984
- My Bike: zxr 400
yes was out on it for the first time on sunday.seemed to run ok.Also noticed when i rev it it drops to 2000 for a few seconds then drops to normal idle.Think i'll just get a mechanic to look at it.RedexRobB wrote:Have you managed to ride it yet?
Does it restart ok?
the revs hanging sound like an air leak.
have a read of this
viewtopic.php?f=1&t=6451&p=50914&hilit= ... evs#p50914
have a read of this
- extonyg
- My Bike: zxr 400 L1 uk
the revs used to hang on my bike due to air leaks from the airbox and from the inlet rubbers, the inlet rubbers made the biggest difference. mixture screws also can also help with revs hanging.
with age the inlet rubbers start to split and perish where they bolt down to the head and also the seals become flat so dont make a good seal.
id say its worth a try having a look yourself before you pay someone else to have a look, there not that hard to work on id say if your hands on sort of person and theres plenty of people on here willing to answer any questions.
hope this helps let us know how you get on
parby81
- My Bike: ZXR400 L9
could just be running a bit lean on idle. On my new one number 4 cylinder was turned down to just half a turn out and it would hang briefly then drop. Turned out to 1 3/4 on all four and there is now no hanging at all. Check the idle mixture screws.
