What engine oil to use?
rickyt28
My Bike: ZXR400 L5
Post by rickyt28 »
Gonna do an oil and filter change on my bike this week at some point, so what oil should i use? Like what viscosity? My bikes done 19k miles. And is it worth using a K&N oil filter (seen um for a tenner) or will a cheaper one be just as good?
Taaa :)
Re: What engine oil to use?
You'll need 10w40 for the engine. Personally I go for castrol gps for mone, others people will vary. As for oil filter if u can get a branded one cheap, go for it.
rickyt28
My Bike: ZXR400 L5
Post by rickyt28 »
Nice one mate, i went for the castrol gps stuff, got it from halfords and just picked up a filter from there aswel coz i wanted to get it done today. I picked up some redex aswel, do you only need a small amount for a full tank of petrol? It says on the bottle, half a bottle (125ml i think) to 50litres of petrol. So i worked it out to be about 40ml redex to 16litres petrol for the zxr. does that sound about right?
Thats spot on by my calculations. They do little 50ml 'shots' of redex and i usually stick that in a full tank of fuel and run that through completely before filling up again. It wont do any harm if you put too much in it'll just smoke a bit, so dont worry about putting too much in. :smt001
rickyt28
My Bike: ZXR400 L5
Post by rickyt28 »
Cooool. Nice one rob, i'll fill her up tomorrow after ive done mi spark plugs and take her for a bit of a blast! weather permitting of course...
rabidnz
My Bike: ZXR400L1
Post by rabidnz »
do you guys use mineral, semisynth or full synthetic oil?
mineral oil? Isnt that what they use to run engines in?
the castrol GPS i use is semi, your hear of clutch slip when you use fully synth but i dont think theres the problems now that you used to get. Ive, heard of people getting clutch slip if they change the oil from synth to semi but thats apparently down to the oils mixing with whats left in the clutch plates..
rickyt28
My Bike: ZXR400 L5
Post by rickyt28 »
Well its the first time i've done an oil change on a bike and i used the Castrol gps that rob has mentioned which is a semi.
I was comparing the botttles in halfords and the fully synthetic Castrol 10w40 said it was for racing, and the semi-synth Castrol 10w40 said it was for normal road use, etc.
rickyt28
My Bike: ZXR400 L5
Post by rickyt28 »
How often should it be changed engine oil by the way??
Not sure what the manual specifies but I think every 2.5 - 3k miles. What you have bought is fine ricky :)
Chadatious
My Bike: ZXR 400 H1
Post by Chadatious »
Hi, just reading above and what is that redex stuff in the petrol for, as ive seen it about, and due to my zxr sitting for 3 years, and getting on road within thext 10 days would it be good to run some through it?
Won't do any harm n you can buy the 'shots' for 1.50 or so, so go for it.
Wabby
My Bike: ZXR400
Post by Wabby »
I went from fully synth to semi over a fortnight ago and no clutch slip yet so shouldnt hurt :smt003
