WORRIED ..
jack sharpezxr 400 L
- My Bike: kawasaki zxr 400 L
WORRIED ..
I TOOK MY BIKE TO KAWASAKI AND THEY TOLD ME MY COMPRESSON WAS AROUND 100 PSI ON EACH CYLINDER BUT MY BIKE IS RESTRICTED TO 33BHP IS THERE ANY ONE ELES OUT THERE WITH A RESTRICTED ONE THAT KNOWSS WAT THEIR COMPRESSION IS .I WOULD MAKE A DIFFRENCE I THINK
- diesel
- My Bike: Zx7r
Re: WORRIED ..
did they say 100psi was wrong? whats your basis for worrying about it?
Re: WORRIED ..
WE;; I TOOK IT THERE FOR A INTERIM SERVICE IT WAS CUTTING OUT ASWELL ON IDLE AND THEY TESTED COMPRESSION THEY SED IT SHUD BE BEETWEEN 190 150I WONDERD IF IT BECAUSE IT IS RESTRICTED
Re: WORRIED ..
I MEAN IT IS RESTRICTEDWOULD THAT LOWER COMPRESSION
lewisdale
- CBT slow
- My Bike: zxr400 H2
Re: WORRIED ..
being restricted wouldnt lower the compression, if its too low then maybe youre head gasket is on its way out or the rings are worn?
Re: WORRIED ..
YH THATS WAT HE SED BUT DO THEY SUFFER WITH BORES WEARING DO U KNOW
lewisdale
- CBT slow
Re: WORRIED ..
i suppose its like anything else, all depends on how it been ridden, if its been well thrashed through its life and how well its been looked after, did they not do a test on the head gasket? as i know this is supposed to be common
Re: WORRIED ..
HOW DO U TEST HEAD GASKET
lewisdale
- CBT slow
Re: WORRIED ..
just looked in the manual mate and from what i can make out it should be between 99-156,
lewisdale
- CBT slow
Re: WORRIED ..
so u should be ok? and they should have a head gasket testing kit, i would have thought, takes 2 mins if its like a car one
lewisdale
- CBT slow
Re: WORRIED ..
have a look 4 yaself http://www.zxrworld.co.uk/Manuals/L%20M ... er%204.pdf
Re: WORRIED ..
SO BASICALLY 100 IS OK YH THEY SAID TO ME IT COULD BE THE BORES THE RINGS THE GASKET THEY SAY THAT TO SCARE U INIT COULD JUST BE HEAD GASKET
lewisdale
- CBT slow
Re: WORRIED ..
well to me if its between what the manual says then i dont think u have a problem there atall, my bike has been doin exactly the sam as youres, just stripped the carbs and found the floats are at different heights!! rubber o rings round the float needle hosing are knackered and the carbs were full of crap so i think thats my problem, and youres may well be the same mate,
Re: WORRIED ..
I WENT IN EARLIER TO SHOP AND THEY TOLD ME ITS NOT STALLING NOW WELL ILL FIND OUT WEN I GET IT .
lewisdale
- CBT slow
Re: WORRIED ..
kool, so what have they done to it then?
