Ok want my h2 to have mph clocks so i just picked up a 'l' mph speedo of ebay for £10 posted w00p.
is this a straight swap for my h2 speedo ? also can you get replacement fascias for them so all my clocks match ?
thats all for now
thanks
not really a problem but more advice needed
WelshD1K
Re: not really a problem but more advice needed
zimms the expert here but if remember right you need a uk cdi too otherwise you'll only get 10k revs out of it.sure zimm will be along to clarify.
WelshD1K
*sits and waits
you'll need a de-restrictor or you'll be limited to 10,000 rpm in all gears
uk spec L cdi, wont work as its an H
- Wabby
- My Bike: ZXR400
Surely the CDI has no effect on the speedo?
Just looked at myn and its cable driven from the front wheel, so should just be plug and play? no?
the stock kph speedo plugs into the wiring loom and sends a signal back to the cdi to tell it wether you are exceeding 180kph or not, if you are it shuts down 2 cylinders. If the cdi doesnt receive a "not exceeding 180kph" signal from the speedo (like when you swap for an mph one that doesnt plug in) the cdi restricts you to 10,000 rpm in all gears.
WelshD1K
so my zxr wont do over 180kmh ??? umm what/ how can i get mph without sticker as they look so nasty
