Need abit of help/advice
AdamZXR
- My Bike: ZXR 400 L8
Hey there guys recently my ZXR has had a nasty rattle it does this when ticking over aswell when you slow down. any guesses as to what is causing this. oh and my friend has his ZXR Restricted any advice on how to take them out. i heard its something to do with the carbs. oh and how easy is it to shorten the exhaust on my bike? as after i let a friend ride my ZXR he had a badger run out infront of him in our local park. and slid the bike. crash protectors saved ALOT of damage only needed a new mirror and well the exhaust just has scratches on it but lost all the Rivets near enough. so just some help would be great. cheers
Re: Need abit of help/advice
the rattle sounds like it might be the cam chain, esecially if it only does it at low revs.
to take the restrictors out you'll be needing this thread:
viewtopic.php?f=55&t=6402
removal is reverse of assembly
As for the can i believe its a case of , cut and re-rivet
AdamZXR
hmmmmmm thanks for that is the cam chain easy to sort is it?? cheers
the cam chain itself is probably fine, i should have elaborated that the rattle is stemming from the tensioner. So perhaps you need a new one
Im not 100% certain about changing the tensioner, plenty of others here have done it tho that can tell you more.
Jeppo
Hi there, new to this forum , will do an intro somepoint soon
I would also be interested in information on how to fit a new camchain.
Also adam, would your friend be willing to send his restrictors my way
AdamZXR
Hi there. possibly i shall have to have a talk with him. however you will have to get a new certificate as his has been used. cheers
Jeppo
I'd appreciate that. I don't need a certificate, just the washers if he would be so kind
