Hi guys, my bike won't rev over 9.5k and won't go over 85mph.
I bought the bike competely unrestricted and put the carb restrictors in myself, why won't it rev up to the redline? there are no other restrictions on the bike as far as I know, any ideas?
Cheers, Nick
Restricted but confused
- UK II Kazawacky
- My Bike: 1991 Kawasaki ZXR 400 L1
Man who lives in glass house should change clothes in basement.
- CaNsA
- My Bike: ZX6R F1
Re: Restricted but confused
Hiya matey.
In the same section that you posted this thread in there are three topics that will help you,
In particular the 3rd one from the top.
De-Restriction Method #1 - Clock Tab Mod
which will give you all the info you need,
this is a guess as i went on the information you have provided.
CaNsA
CaNsA
- extonyg
- My Bike: zxr 400 L1 uk
if it was totally unrestricted when you got it..........did it rev to the redline before you put the restrictors in?will it rev past 9k in lower gears before 85mph?.........maybe it could be that the inlets where you have put the restrictors needs sealing up as they can cause airleaks, causing poor running
extonyg wrote:if it was totally unrestricted when you got it..........did it rev to the redline before you put the restrictors in?will it rev past 9k in lower gears before 85mph?.........maybe it could be that the inlets where you have put the restrictors needs sealing up as they can cause airleaks, causing poor running
My thoughts exactly.....................
Was the bike running ok reving out properly...............before you fitted the restricters ?
- UK II Kazawacky
Cheers for the pointer CaNsA, but my bike isn't an import, I don't know whether that info makes a difference or not.
There were a lot of problems with the bike before I fitted the restrictors, so I didn't actually run it, but I may take them out and try again, I put silicon grease round the restrictors and my dad said that would stop any air from getting in, he's been riding and maintaining bikes for 35 years so I just went by his word as you can imagine.
I've just balanced the carbs and put new spark plugs in, it doesn't seem to have made much of a difference, it runs smoother at idle but still doesn't rev past 8.5k
It revs up to about 9.5k in 1st and 2nd, there seems to be no power after 8.5k in the rest of the gears so I don't bother going past 8k.will it rev past 9k in lower gears before 85mph?.........
- extonyg
after time and with the heat 'silicon grease' will just disappear needs to be a 'silicon sealant' of some form......on the mounting faces of the restrictors to the head mainly and make sure the inlet rubbers are ok.a good way to test this is when the bike is running spray some carb cleaner or wd-40 of some kind around the inlets and if they are 'leaking' or letting air in the idle will change.
you say the bike had alot of problems before you fitted the restrictors.........what like???running problems???have these now been rectified?
