slip on - bolt on adapter
muffinman
ive got a micron bolt on race can, and i need an adapter so i can use it with my micron system
does anyone know the hole distances on a micron can, possibly suzuki and kwak?
would this work?
http://cgi.ebay.co.uk/SUZUKI-BANDIT-120 ... dZViewItem
would this work?
Northern ANdy
- My Bike: Unique ZXR400
Re: slip on - bolt on adapter
if you have the same microns as me, then the slip on dia is 63mm not 50mm so its not a go er. I have semi same problem but not in a hurry to put my old can back on.
Andy
sic1181
if anyone wants to use there standard down pipes with a slip on race tin u can angle gring the flange off which the tri bolt can goes on, then u can split the exhaust n rip out the baffle then mig weld it back together
. Sounds amazing
Ghost Rider Is God!
muffinman
i need to do that the other way round, im thinking about welding my 3 bolt flange to my micron system instead
i really dont want to run my road legal can!
Northern ANdy
I chopped the end of my old standard down pipes off, but I have just bought a new can and the mounts are triangle at 87mm hole centres, just going to have to go to a stainless supplier and burn a plate up for myself. A machine shop could easily fabricate what you want.
Andy
f17th
Is there an adapter to fit over Micron Downpipes to fit a standard exhaust ?
(When i say standard i mean standard fit, I have a spare stainless race can)
Not sure i like the Micron Can, Its rather Large! Sounds quite nice, so cant complain there
muffinman
thats exactly what i want, i think its a case of getting one made upf17th wrote:Is there an adapter to fit over Micron Downpipes to fit a standard exhaust ?
Northern ANdy
If you're handy with a welder you need a plate, a drill, a piece of pipe 63mm ID, and no thicker than 1.5mm wall, and a saw. I've managed to get some stainless arc welding rods so the job doesn't rust.
Andy
muffinman
i have found a better idea,
getting a custom carbon can made instead
f17th
How much is that going to cost tho ?
Let me know the details.
muffinman
165quid on ebay
f17th
Got a link ?
And is that a slip on 63mm ?
Not sure I want to pay that much for an End Can, I only paid 200 for the full micron system
Northern ANdy
muffinman
northern andy, sounds like its blowing?
i dont think £165 is too bad for a custom can, and it will fit 63mm micron downpipes
link:
http://cgi.ebay.co.uk/Kawasaki-ZX-6R-7R ... dZViewItem
link:
Northern ANdy
it is blowing, I only stuck it on with a rag around the link pipe, havn't made the adaptor yet.
Andy
