My ZXR is showing symptoms of running very lean, so much so that it stalls if left to idle. I have ruled out most of the posibilities of this now - e.g vacuum leak, blocked pilot.
I haven't had a close look at it but have noticed in the past that my downpipes are thick with rust, could a hole in the pipe cause my bike to run this bad?
Exhaust leak - run lean?
Flatowtornowt
Re: Exhaust leak - run lean?
wouldnt have thought so it should run even with no exhaust headers on
Vaughn
- My Bike: Zxr400
Would definitely need some ear protectors for that experimentFlatowtornowt wrote:wouldnt have thought so it should run even with no exhaust headers on
