From looking at various ZXR L models it seems that some are bolt on and some are slip on.
Was there only a certain period that they were bolt on?
Standard can
- CBT slow
- My Bike: zxr400 H2
Re: Standard can
bolt ons are standard front pipe, slip on is aftermarket
Re: Standard can
And if its too loud one of us (cough me ) might have it
- CBT slow
Re: Standard can
lmao i dont need it mine is really loud, so i put the baffles in and its hardly made a difference
- My Bike: zxr400 L
Re: Standard can
sooo finally got the scorpion on. seems to idle a tad louder but same as standard but deeper tone
- My Bike: ZXR400 L1
Re: Standard can
mine came with a micron end can onit. was reaally loud with the four rust holes it also had throughout the exhaust but they're all sealed up now
"If it's not broken, fix it 'till it is - If your not sure how it works, take it apart and find out - If it don't work when you put it back together.......look in the manual"
- My Bike: zxr400 L
Re: Standard can
is micron louder than scorpion? i think standard sounds a bit better for some reason...Tom1528 wrote:mine came with a micron end can onit. was reaally loud with the four rust holes it also had throughout the exhaust but they're all sealed up now
Re: Standard can
not sure..i expect scorpion are loudedr. ive heard a scorpion can on a ybr125 and it sounded like a 400. my micron still shakes the ground tho! hahanc73 wrote:is micron louder than scorpion? i think standard sounds a bit better for some reason...Tom1528 wrote:mine came with a micron end can onit. was reaally loud with the four rust holes it also had throughout the exhaust but they're all sealed up now
Re: Standard can
bahh whats every ones problem the louder the better!!!
hence why ill keep the revs higher than ushuall on the zxr with the renagade can just so i smile at the burble!!
