Which race can
Which race can
Hello, I have just got hold of a set of micron delta down pipes, but, no end can.
Does anyone know where I can get a new micron race can from?
Or can anyone recommend a different make of can that will fit the micron pipes?
Cheer's Nick.
Cheer's Nick.
Re: Which race can
is that the slip on version?? have you tried scorpion?
Re: Which race can
Hello, yes it is a slip on can, I have not seen a micron race can, but, I assume it has some sort of clamp to tighten around the exit pipe.
I will send scorpon an e-mail.
Cheer's Nick.
Cheer's Nick.
- My Bike: zx7r p6
Re: Which race can
try exhaust technologies for micron race can, thats where my full micron system came from anyhow.
Re: Which race can
you'll be able to fit any can you want as long as its slip and the same inlet size
- My Bike: Unique ZXR400
Re: Which race can
carbon can co, quill ect any can builder will be able to id expect
Re: Which race can
at cost though. 63mm isn't a run of the mill size, its needs rolling or swaging out from 2 1/2"
I've been quoted £50 plus just for the pipe to be rolled, seam welded and then butt welded into a plate that will accept a bolt on can.
Andy
Re: Which race can
yoshi are 62-63mm.
Re: Which race can
Cheer's for the replys, I googled exhaust technologies and it brings up Micron themselves, I have asked and they have no stock.
I will wait a few weeks and see if I can get hold of a second hand one, if not looks like I will be enquiring for a custom fit can.
Thanks again, Nick.
Thanks again, Nick.
- My Bike: zxr400l4 zx7r
Re: Which race can
i asked carbon can co in january at excell show. they said no problem. at nec show they said no way! i found one from fuel, stainless stubby oval race delivered for 145 quid. sounds like a tank now rather than an asthmatic washing machine.
anything is possible with enough time and money. and an open mind...
- jake
Re: Which race can
id just run the open pipe dude
Re: Which race can
Thank you for the help, now have a micron race can.
Just got to find the time to fit it all and the money to get it set up.
Cheer's Nick.
Cheer's Nick.
- My Bike: zx7r p6
Re: Which race can
are you confident in setting up the jets yourself?
Re: Which race can
No. I have no experience of setting a bike up. I have contacted road and track in Aylesbury, they have been highly recommended, I will be letting them do the work. He said a mixture of dyno jet parts and kawasaki parts was the best way to go about things.
