Rear seat stuck
jonny
My Bike: zxr400 L2
Rear seat stuck
Post by jonny »
Not sure how it has happened but my pillion seat isn't on straight and when I try to remove it with the key it has no effect. The key turns but nothing happens. I assume it is cause the seat isn't on straight.
Does anybody know how I can remove the rear seat without a key? Any help you can give is greatly appreciated.
tgal7032
My Bike: ZXR400 L2
Re: Rear seat stuck
Post by tgal7032 »
Push down on the back of the seat while turning the key and it should lift off.
Re: Rear seat stuck
If you can reach it tug on the cable that goes from the key lock to the seat latch. That should ooen it too.
jonny
My Bike: zxr400 L2
Re: Rear seat stuck
Post by jonny »
Thanks for the advice. I couldn't get my fat fingers in to reach the cable but managed to get it off by pushing quite hard on the seat while turning the key.
Thanks!
