Need To Learn How To Spray Paint - PROPERLY
- SimonH
- toykaboy
Guest
Leemc2004
That was my post above, thought I was logged in.. and just incase anyone asks.. the flat black colour is intentional. I wanted a satin finish because it was original... harder to clean though!
Lee
Lee
1993 - ZXR400L2 - Matt Black - Gold Wheels - Scorpion System - Blueflame EVO Can - DynoJet Stage 1 - K&N Filtercharger - Skidmarx DB Screen.
- wonderpupp
- My Bike: ZX6R P7F
- Haggis
- My Bike: ZRX1200s
Re: Need To Learn How To Spray Paint - PROPERLY
Just a word of warning. I painted my wife's old CBR400RR (cough, spit) using Halfords paint and lacquer.
I used a compressor and a proper air-gun for it all.
The paint went on fine (only one run, where it wasn't too obvious) 7~8 coats.
Lots of careful rubbing down, lots of cleaning, lots of effort and attention to detail.
The stickers went on, again lots of attention to detail, getting them straight and in the right places, bla, bla, bla.
The lacquer went on fine (no runs) ~ 10 coats.
Polished up and nice 'n shiny!
Then it went onto the trailer to head to Snetterton. I had the idea that it would be cheaper to fill the tank as I filled the car (go-juice at Snett is NOT cheap).
As I was clambering off the trailer, I managed to dribble some petrol on the tank.
I grabbed a tissue and wiped.
Off came the lacquer and the paint!
When I stormed into Halfords the next day, they quite calmly told me that their lacquer isn't supposed to be petrol resistant.
It's cheap (actually it's not) and cheerful (actually it's not) and it's your money (not once they have it!), so make your choice, but bear this tale of woe in mind. You get what you pay for!
There's no substitute for cubes!
CarneyUK
I did my bike myself and then got a pro to do the final laquer stage. All paint from Halfords.......they say the final laquer stage makes up 80% of the standard of finish.
viewtopic.php?f=20&t=4358&st=0&sk=t&sd=a
I used 80 Grit to start with then 400 grit . Once primed 1200 grit....colour coat then 1500 grit for final laquer. I did 2 wet coats on all then gritted when dry. then another 2 coats then dry gritted.wonderpupp wrote:What's involved in the prepping, or did I miss that bit?
What grade of sandypaper do you use to get all the old paint off?
ive done the halfords rattle can thing in the past and yeh, petrol just takes it straight back off, even if you've used the corresponding lacquer... which you have to, as proper lacquer takes the paint off too .. lol .. it is after all acrylic paint ..
recently ive done two bikes (both zxr400's) in 2 pack, one kwak green, one "aircraft blue" goes on lovely, didnt need to lacquer it, just did 3 coats, left it a week or so and t-cut'd it back to flat and polished with decent car wax.. looks great. 2 pack tends to cover slight imperfections nicely too, unlike cellulose which does its best to accentuate every last niggly bit.
no problems with flex etc ..
that paint job cost me £40 and took about an hour and a half.. which worked out cheaper and quicker than halfords spray on/wipe off shite.. course you need a compressor and a decent gun ..
no pics of the blue one.
doing my car in satin black this week, although using cellulose as getting a consistent satin/matt effect with 2 pack is a nightmare.. specially if you need/want to re-do parts of it again at a later date
- Haggis
- My Bike: ZRX1200s
On the subject of 2-pack: Do you wear the fancy face mask with filtered air supply or just keep everything well ventilated?
I found some paint from Standox http://www.standox.co.uk/portal/en?page ... al_Colours. Their 'Exclusive line' is well worth a look (The Daytona Paradise is my current favourite), but at £260 a litre it'll have to wait until the Lotto is nice to me.
Check out their Data Sheets too, they give loads of tips about painting.
