When I push my lights switch to the far left (For all lights to be on, main beam and side beam) only the side beam comes on
Obviously the switch to go between main beam and high beam on the left hand switchgear dosent work either
WHen I press the PASS button however my high beam works, both bulbs light up so its not as if the bulbs are blown
Any Ideas?
						Main Beam
Re: Main Beam
check the wiring to the right hand switch gear, and the fuses, ive a feeling the "pass" switch bypasses the stuff and can work even if the rest is shot.
				-Eddy-
Re: Main Beam
Cheers, Im guessing you mean the fuses under the seat? they are fine
Re: Main Beam
have you checked the headlight relay?
				nitro_rhys
Re: Main Beam
iv got a problem with this too mines the import so i just have the controls on the left and dipped beam works fine but when i change it to main beam theres nothing
Re: Main Beam
join the club mate viewtopic.php?f=7&t=5570
