A few months ago I replaced the rectifier on the ZXR. When I stripped the rectifier off, I found that the connector block looked like this:
I plugged the new rectifier in, and it appeared to be working i.e. bike was charging when running.
This worked for a while, but I suspect that the contacts in the block are iffy, and so has failed again. Can anyone either supply me with one of these connector blocks, or tell me where I can order an original/pattern from. I rang the local Kwak agent, but he told me I need to order the whole loom (yeah right), but he has been known to be wrong on things before
Help would be appreciated please ...
