Main Beam and indicator problem
				owainzxr400
The problem i am having is that the main beam and indicators have stopped working. the dip light works on the headlight and the side light, but no main beam and this is a bit of a pig because of the nice weather and m.o.t. coming up.
When i press the pass switch to activate the main beam i hear a relay working but no light and if i press the indicators to either side i hear and see nothin.
i was wondering if it could be both the relays are gone?
Please help
Please help
hiya and welcome to the forum
Have you checked the fuses? I think the indicators and main beam lights are wired into the same circuit. But are seperate from dipped beam.
p.s. we have manuals here for your reference
				owainzxr400
Ye have checked the fuses and the blubs and their all working fine. i was thinking another option from the relays could be the actual fuse box it's self but also noticed that the indictors dont run off the fuses, well it doesnt say it does on the fuses box any way. it's an L reg (1994) is thas any help.
Any idea how much the two relays would cost?
				owainzxr400
http://www.zxrworld.co.uk/Manuals/L%20M ... r%2015.pdf
page 35, tells you how to test the fuse box, got a multimeter?
				owainzxr400
Thats what we are here for mate, no problem at allowainzxr400 wrote: cant stressw how much of a help you've been.
That little sign means infinity, or open circuit in electrical terms. Im not sure what your meter will say when you check for an open circuit it usuaully deends on the make. But look in the user manual for the meter and it will probably tell you.
- deviant
 - My Bike: ZXR400 L3
but it will be something other than a number!RobB wrote:Im not sure what your meter will say when you check for an open circuit it usuaully deends on the make.
