Hello!
Hoping this hasnt been asked before as I couldnt find a post with the same issue.
I have a ZXR 400 L1 race bike which has had the clutch switch removed but not bypassed.
On the wiring diagram am I correct in thinking that the 2 blocked connector after the neutral switch should be where the standard cable plugs in to a bullet connector and then to the two pin?
I have tried bridging the wires just before the 2 pin connector and I cannot get the bike to start in gear at all which is a pain when i managed to stall it in the pits.
Could anyone offer some advice? Can provide pictures if what I have described is not clear
Clutch Bypass Question
stranger255
- My Bike: Aprillia Shiver
Re: Clutch Bypass Question
if your clutch switch has been removed but not bypassed your bike will NEVER start in gear, you need to connect the black wire to the black/yellow wire so the CDI thinks you are always in neutral (this should be a 3-wire plug).
the 2 wire connection near the neutral switch is for the side-stand switch, again you need to bridge the connectors otherwise the bike will think you have kicked your sidestand out...and wont fire.
stranger255
Ahh brilliant, the 2 pin one appears to already have been bypassed as the bike fires perfectly.
I will now need to go digging for where the hell he has hidden the 3 pin connector!
stranger255
Cheers banner, got it all sorted now and even managed to fix another issue with your guidance
