Evening.
Everything on my dash lihts up llovely except the temp gauge, is it supposed too?
L1 400.
temp gauge
Re: temp gauge
yes
If you look on the parts list or the manual or the microfiche you would see a bulb is fitted into the temp gauge.........................took you longer to type your question then it took me to double check for you.
Re: temp gauge
Jonjo wrote:Thanks
