Race loom Diagram
ChowderV4
My Bike: Zxr400L racer
Race loom Diagram
Post by ChowderV4 »
ok so im currently making a race loom out of my road loom now i found a race loom diagram someone had made, but it included the charging system, regulator/alternator.
This:
Now im running total loss , ive edited out what i thinki dont need on this photo, can someone confirm that im not comepletely useless with wiring
Total Loss Edit:
Re: Race loom Diagram
looks correct to me, ive done colour maps of the L1-5 wiring diagram, along with detailed steps on how to convert to a race loom, as well as removing the fuel pump, alternator reg/rec, and starter motor (for those with a race starter).
one thing i would add, is if you run total loss and can be forgetfull wire back in your oil pressure light. no only will this indicate if you get a total loss of oil pressure, but when the bike is running the light will be off, and it will come back on when you hit the kill switch...its a good reminder to disconnect your battery at the end of a session/night.
CaNsA
My Bike: ZX6R F1
Post by CaNsA »
Did you check the race manual?
http://www.zxrworld.co.uk/Manuals/zxr400r.pdf
ChowderV4
Post by ChowderV4 »
cheers for the replies, im pretty sure ive done everything right, only have to solder a few wires together now and solder in the resistor.
Yeah i was planning to keep the oil pressure light, its not really worth wiring in the neutral light is there?
I will see if ive done everything right soon when i try starting it :pmsl
ChowderV4 wrote:cheers for the replies, im pretty sure ive done everything right, only have to solder a few wires together now and solder in the resistor.
again, neutral light is up to you, but its easier to see if you're in neutral than to see that you have oil pressure...
ive written a post about the L1-L4 (L5 is almost the same) wiring along with a conversion to a full race loom (-alternator, -fuel pump relay, -starter) if you need to double check.
ChowderV4
Post by ChowderV4 »
ok so ive plugged everything into the loom, i have power, temp guage moves when killswitch is on.
When i press the starter i get a click from the starter solonoid the tacho will move if the start button is held down, but it isnt cranking.
Any ideas before i start panicing , i have followed the race diagram on here
ChowderV4
Post by ChowderV4 »
and in regards to the resistor i used these http://www.ebay.co.uk/itm/111255175253? ... 1439.l2649
was told blue 100 ohms , is that different to these , and have i got the wrong ones
0.25W...im pretty sure if you dont want it to burn out you will need at least 1W.
matthew
My Bike: zxr400
Post by matthew »
ChowderV4 wrote: by ChowderV4 » Sat Feb 01, 2014 2:38 pm
I would get intouch with Rodger at rmkd if i wer you hes a genious with wireing an will tel you over the phone wats wrong. He told me last week wen i had trouble that their was a race loom on hear somewhere that wasnt right :smt017
ChowderV4
Post by ChowderV4 »
cheers for that, if the new resistor doesnt sort it i will give him a ring
