Hi Guys,
Recently my left indicator has gone a bit dodgy...
Basically when I switch the left indicator on, the rear indicator lights up, but stays lit up, (does not flash) whilst this happens the front indicator does not turn on whatsoever, and the light under the clocks that tells you when it's on stays on without flashing aswell.
My right indicator works perfectly.
At first I thought it is the indicator relay, but the right indicator would also be faulty if it was?
Any ideas?
Thanks!
Indicator...Help??
JamieNeve
- My Bike: CBR600RR, ZXR400 L-2
Re: Indicator...Help??
swap bulbs from left side into right side and vice versa and see if the problem persists, if the problem is still there then its either a bad contact in the indicator switch gear, or relay.
JamieNeve
Yeah, ended up being a faulty bulb!
Thanks for your help!
