Right,
Now I am pretty sure my bike is fitted with LED lighting (not totally sure, will be checking it out later).
Wanting to get some of those in fairing LED front indicators.
First of all how would I know if my bike has already got a relay switch attached..... and where do I find it on the bike?
Is it difficult to fit if I don't have one?
Thanks,
Ben
Indicator flasher relay?
Re: Indicator flasher relay?
you will have a relay switch, if not your lights wont flash at all.
you are likely to have 1 of 3 setups:-
bulbs on standard flasher.
led's on standard flasher with resistors.
led's on led flasher, no resistors.
fitting an led flasher relay is dead simple, fit a 3-pin led flasher relay (http://www.sportsbikeshop.co.uk/motorcy ... 833)...and fit LED lights...simples, 5 minutes to fit and no resistors to wire and get friggin hot!
flasher relay is LHS under the rear panels.
