Clocks
Posted: Tue Oct 23, 2012 12:32 pm
by 2802dan
Is there a way of changing the colour of the clocks from orange?
Re: Clocks
Posted: Wed Oct 24, 2012 2:09 pm
by syihabuddin
You can try LEDs? Dont think it'll be as easy as it sounds though.
That's what ive seen people do with the aftermarket meters and clocks.
Re: Clocks
Posted: Fri Oct 26, 2012 4:38 pm
by Tirpitz
No, because the colour doesn't come from the lamp (which is white) it comes from the colour of the clock face through which it is shining (which is orange). You would have to change the clock faces, which is going to be a right PITA.
Re: Clocks
Posted: Sun Oct 28, 2012 6:20 am
or change the clocks completely to something new and different, KOSO clocks would be good
Re: Clocks
Posted: Fri Nov 09, 2012 6:25 pm
by Big Hoddie
I've thought about koso clocks for next summer-how easy are they to mount and wire in?
Also, I've got a 93 bike so the stock clocks are in kph, troubles is, with it being winter, most of my riding's done in the dark so I struggle to see the mph sticker. As I can't find a cable converter and have a perfectly decent set of uk clocks here, if I buy a uk speedo drive (the thing at the wheel) will this make the clocks read in mph, or will connecting the clocks to the current drive be enough?
Re: Clocks
Posted: Fri Nov 09, 2012 6:43 pm
by banner001
Big Hoddie wrote:I've thought about koso clocks for next summer-how easy are they to mount and wire in?
2 seconds of ebay gives me
http://www.ebay.co.uk/itm/SPEEDO-DRIVE- ... 4abe1f88bc
Re: Clocks
Posted: Fri Nov 09, 2012 8:13 pm
by Big Hoddie
Yeah, and if that goes, I'm in the same situation. So answer my question bout the uk clocks and drives or leave me alone dude. Seriously getting on my nerves
Re: Clocks
Posted: Fri Nov 09, 2012 9:03 pm
by Ewetea
I must start by saying that I am not an expert, but I reason that the angle drive fitted to the front wheel is a standard item that just enables the rotation of the front wheel to be turned through 90degrees to rotate the speedo cable. The gearing takes place in the clocks to give either kph or mph. That is why one of those blue adaptors must be installed in-line to rotate the gears in a kph clock slower so that the needle shows mph. I have a spare blue adaptor, and 8flats rotation on the input side produces 5flats rotation on the output side. Since 8km represents 5miles (roughly), a kph clock will be showing mph. If you have some UK clocks, which I assume read mph, then they should read correctly when connected to your existing angle drive. The easiest way to check will be to ride the bike in top gear and note the revs at say 80kph. Then just lash the UK clock to the bike, attach the speedo cable and check that at 50mph on this clock that the revs are still the same in top gear. Do let us know if it works - for reference.
Re: Clocks
Posted: Sun Nov 11, 2012 11:22 pm
by Tirpitz
Big Hoddie wrote:Yeah, and if that goes, I'm in the same situation. So answer my question bout the uk clocks and drives or leave me alone dude. Seriously getting on my nerves
You say "I can't find a cable converter......"
Banner001 posts you a link to a cable converter.
You snap his head off like he's being unhelpful.
Re: Clocks
Posted: Mon Nov 12, 2012 1:01 am
by Big Hoddie
Looks like I have a lot to do this weekend. And yes, I was being unreasonable, I apologised on another thread.
Re: Clocks
Posted: Sun Dec 02, 2012 11:05 am
by Big Hoddie
Koso clocks use a fuel gauge-is there any fuel sensor that I can weld in the tank? On my nsr, I stuck a cbr125's sensor in the tank
