fitted front and rear led indicators and also led flasher relay
first problem i had was when i indicated right all four flashed and the same when i indicated left, after removing the bulb on the indicator reminder the problem was solved indicate left and left flash and same with the right.
But then i fitted a led bulb in the reminder light and its back to all four flashing.
Anyone know how to solve it?
