Hello all,
I need help my ZXR 400 has an electrical fault as in i have none.
Got it out ready for mot today started 1st time turned it off went in to put my gear on came out wheeled it to the road and nothing totally dead no ignition lights no lights nothing!!!
Battery is new 1 week old, changed main fuse, cleaned and added a new earth.
I can get it to turn over by a wire between starter solnoid but will not fire.
Been on here and had al look at similar cases all pointing to ignitioon switch.
Needless to say no mot today only sunburnt neck to show for my effort.
Any advice welcome thanks!!!!
ELECTICAL FAULT ??? HELP REQD PLEASE
- DRAINPIPE16
- My Bike: kawasaki ZXR 400
Re: ELECTICAL FAULT ??? HELP REQD PLEASE
You havent go tthe kill switch on have you?? Its worth looking at the side stand switch too, as I had problems with that last year, its should just need a clean. Check the connector block for the ignition too.
- DRAINPIPE16
Thanks for the help checked em all in the end turned out to be ignition switch so new one now fitted and started first time.
Well happy now back in buiss!!!!
