starter motor not working and click coming from fuse box
callum@93
- My Bike: zxr 400 L8
tonight i took my batterie out to charge it, before hand the bike was running and turning over fine. Then after i put the charged batterie back in when i press the ingnition button there is justa click comes from the fuse box and thats all
Re: starter motor not working and click coming from fuse box
sounds to me like your battery is not charged
callum@93
hello mate, i have just put a battery on that i know has charge (the horn works and all the lights are on) and i still have the same problem iv checked the fuses and they all seem fine.
haha it likes to fight ya this bike.
Im guessing that the clicking is coming from the starter solenoid that is a classic symptom of a weak batteryor maybe a poor connection between battery and solenoid. If you short the large solenoi connections wi0a screwdriver the starter night turn the bike over in which care you could have faulty solenoid. But it is weak battery is my bet.
callum@93
ok chears mate, il give it a try
callum@93
ok i shorted it with a screw driver and it did turn
so i gues thats what it is.
seems likely to me............
