Back light problem
rossd
Back light problem
Post by rossd »
Hi guys, just noticed my back light playing up. The back light works as normal untill the lights are turned on and then it dosent do anything even if the brakes are pressed, but when the lights are turned off and the brakes are pressed the light works :S cheers guys.
lewisdale
CBT slow
CBT slow
My Bike: zxr400 H2
Re: Back light problem
Post by lewisdale »
check the earth points, and wiring connectors, also make sure the bulb is connecthing properly in the fitting
