zxr400 h1 rectifier plug burnt out
bilboaustin
- My Bike: zxr400 h1
Hi everyone, working on my brothers h1 the other day investigating a poor starting issue and I noticed the plug going to the rectifier is burnt out. Is the plug the same as an L9 or will I have to use another h1 plug?
Re: zxr400 h1 rectifier plug burnt out
can you post a pic?
the L9 should be a standard large 6 pin (2 x 3) white connector.
if not you can use standard 6.3mm female spade connectors and just splice them into the loom.
i would also be investigating why it burnt out, was it on the main power (its the white wire on the L models) line?
