i thought i had fixed my sidestand switch but not.
basically if i put bike in gear with stand down, the bike will still try to fire,
so i did the same thing but with stand up and held the switch all the way in with my thumb, and the bike wont start,.
so this suggests the stand aint pressin the switch in enuf. can i bend the lip on the stand a little to make it press switch in further? or put a sort of cap over end of switch so it has a few extra mm of travel? or change the switch?
or does the sidestand have adjestment on it?
'Kin Sidestand
- Gemini
- cloning technology
'Kin Sidestand
- My Bike: zx7r p6
Re: 'Kin Sidestand
switch will most likely have position adjustment, be a case of slacken its bolt off and reposition it id of thought
- Jamz
- My Bike: Kawasaki ZX9-R C2
Re: 'Kin Sidestand
So it's working normally except you can start it when it's in gear with the stand down?
I'd say forget about it (well, actually I'd probably say "Ey! Forgeddaboudit, ya fokkin bum!") - unless your Neutral light doesn't work or you've got a habit of starting the bike in gear whilst stood next to it.
At least it's not stopping the bike moving!
- Gemini
Re: 'Kin Sidestand
yeah its doin what ur sayin,and its not stopping bike from working, and i always check sidestand is up b4 is ride off, but it bugs me when things dont work as they should
