Swing arm info please??
jamieofleeds
Post by jamieofleeds »
Hi every one i am looking for a little bit of information as i own a zxr400 l2? (1992) i am about to change the swing arm after i have painted my spare one can any one tellme how many bearings are in the swing arm as my manual says one but i dont understand why there would be only one as its got two sides just like a wheel??
Thanks Jamie
Miles
My Bike: ZXR 400 L3
Re: Swing arm info please??
Post by Miles »
Hey there. There is one ball-bearing type bearing on the left of the swing arm and needle-type bearings located in the shaft of the swing-arm. I can't remember how many but I do know their abit of a nightmare to get out (The needle type not the ball-bearing, it just comes out with circlip removed and a hammer)
The expoloded drawing in the manual is very clear ? ? ?
I see four bearings 3 needle rollers and a roller bearing
jamieofleeds
I see 1 bearing on the right hand side and its good but the circlip os broken at one side any suggegstions how to remove this ?? unless i am not reaind the diagram right i will doubble check it
Thanks guys
