Hi guys,
hoping somebody can help clear this one up, i've come to refit the headstock bearings on the zxr400 H1 but i think i've been sent out the wrong ones as there appears to be a 1mm discrepancy, the tube is 46mm Ø and the bearing has 47mm Ø this is the same top and bottom so the bearings don't appear to be sided.
Unfortunately i don't have the originals to compare to anymore and whilst i've tried to search the old internet for the original dimensions i can't seem to find them, has anyone got any idea as to what they are so i can see if these are the wrong ones, a 1mm tolerance seems a awful lot.
thanks in advance
headstock bearings
- CaNsA
- My Bike: ZX6R F1
Re: headstock bearings
What part numbers did you order?
What part numbers are on the bearings?
mentalminis
I'm away from the house at the moment but I purchased the bearings through wemoto and they only list a description not part numbers, I've tried to find the bearings on the microfiche but I can't see them anywhere
mentalminis
right the code on the bearing is 32005
mentalminis
just been checking out ebay and managed to find a listing that states the dimensions and they are the same as the bearing i have
http://www.ebay.co.uk/itm/Kawasaki-ZXR- ... 415dbb8b31
so i'm all good, it's just a really really tight fit, seem ok to you cansa??
