Cracking noise from front end
georgarasx
My Bike: ZXR 400L
Post by georgarasx »
Good evening guys, I have my zxr for quite some time now and i have recently ghanged the tyres. As from the I have this problem. When I use the front brake hard or when I get through a bump, I can hear a loud cracking noise coming from the top of the bike' s front end. What could this sound be related to? I can also hear it while i accelerate after breaking... Pretty annoying
Re: Cracking noise from front end
might be headstock bearings?
get a couple of friends to lift the front of the bike up by the handlebars and see if you can pull the front wheel towards and away from you, if there is movement its probably headstock bearings, or a loose yoke nut.
georgarasx
My Bike: ZXR 400L
This is what I was thinking. I lifted the bike and tried really hard to make the noise but it had no effect, the front system isn't moving. Anyway, i took the upper plate out and greased the bearings. Could the noise possibly be coming from the rear. It echoes through the whole frame. Before sometime I had a blown headgasket too and the situation is really frustrating... Anyway, I keep doing whatever I can... Love my bike!!!
EDIT: sound still there, wander if it could be coming from the forks....
400y
My Bike: ZXR400H1 GSXR600
Post by 400y »
Could be the brake discs. Flex them and see how much movement there is.
^ was gonna be my next thing, check fluid levels too, could be a small airlock
georgarasx
My Bike: ZXR 400L
Good morning and thank you for the suggestions (didn't expect for so much attention in a forum, I am new to these). Just tried to flex the disks, can't flex them for sure and they don't move in a way they shouldn' t, although some minor sound comes from them, when I pull them. I also changed the brake fluid. Problem still there, but: After some riding I have noticed that there is more sound as the bike rises temperature. This is notable when encountering bumpy roads. I think I can feel the cracking in my right hand, holding the handle bar.
ross46
My Bike: zxr 400 l6
Post by ross46 »
random idea, could it be the pads moving in the calipers? if you slam on the brake hard and there is some movement im guessing the could move and hit inside the caliper?
georgarasx
My Bike: ZXR 400L
ross46 wrote:random idea, could it be the pads moving in the calipers? if you slam on the brake hard and there is some movement im guessing the could move and hit inside the caliper?
I don't think so, because, the sound is still there when I open the throtlle after the breaking or when I go through a bump on the road without touching the breaks.
ross46
My Bike: zxr 400 l6
Post by ross46 »
Hmm, try checking all the suspension and subframe bolts, I had 3 subframe bolts missing, scared me when I saw it
georgarasx
My Bike: ZXR 400L
Bad one with the missing bolts... I checked, all there. I messed up a bit with the front fork settings taking them back in the factory preset and the sound is less annoying but there. It's a cricking now if I could describe it :-P the guy I bought the bike had them messed up for good.
