Hi,
I currently have a H model with the zx6 forks conversion done but looking to change back to standard for racing with CRMC. I can only find L forks, will these fit the H model or what else is different?
Help!! Will an L front end fit a H model
Kieronsmithh
- My Bike: Zxr400 H
Ewetea
- My Bike: ZXR400L5
Re: Help!! Will an L front end fit a H model
I'll tell you what I know. The L forks increase in diameter from 50mm diameter in the top yoke to 52 diameter in the bottom yoke.
I think that the H1 forks were 50mm diameter all the way down the leg. You didn't say if yours was H1 or H2. I also think that the wheel spindle was a different diameter between the H1 and L models. The L model is 20mm diameter.
