is there any one that can help me rebuild a 91 zxr400 fnt end ie step by step! my forks are bent, radiator bent, the clocks and headlight have had it along with ma tank an fairing. i cn do most of the rebuild maself but being as i dnt have a clue ne help wuld b much appreached. its mainly the forks that is the biggest problem but any and all help pls
thank u
near write off
- My Bike: ZZR1100C3
Re: near write off
If its a H model I can supply you a set of clocks and headlights already mounted on the bracket, ready to bolt on (bolts included).shaq wrote:is there any one that can help me rebuild a 91 zxr400 fnt end ie step by step! my forks are bent, radiator bent, the clocks and headlight have had it along with ma tank an fairing. i cn do most of the rebuild maself but being as i dnt have a clue ne help wuld b much appreached. its mainly the forks that is the biggest problem but any and all help pls
thank u
£35 + p&p
I also have a tatty old tank you can have for a tenner. I also have tatty fairing panels you can have for £10 each.
zxr400 h2 (breaking)
zzr1100c3 (broken)
Vespa et4 (almost broken)
My FleaBay
zzr1100c3 (broken)
My FleaBay
- diesel
- My Bike: Zx7r
Re: near write off
oh crap. ive just binned a set of H1 forks . i think all i may have are the gold outer legs
