The forks are waisted between the top and bottom yokes, as they are 25mm longer so you will probably need a 1mm sleeve made up to clamp the clipons too depending how far through the yokes you have the forks poking, you'll lose 25mm of the bit where the zx6 clipons clamp too if you have the 25mm showing above the yokes. There may be enough there, but I have mine a further 15 mm through so lose even more. Having said that, if you use the 400 clipons, they bolt to the yoke anyway, so probably not so much of an issue even if you lose a bit of meat to clamp too.
Sorry, that's a bit of a waffle
