Brakes
Re: Brakes
you will need to bleed it mate, easy enough job.
- My Bike: zxr 400
Re: Brakes
Nice one have them off now going to give them a very good clean think one of the pistons is sticking,so is it best to buy new one?masterofinsanity wrote:you will need to bleed it mate, easy enough job.
Re: Brakes
nah whip it ou and give it a good polish up, just dont grip it with pliers or the vice as it will gouge it.
- My Bike: zxr 400
Re: Brakes
how do i get the piston out after i have taken it all apart should i have done this before i took the fluid out.i also sprayed the whole caliper with brake cleaner and scrubbed with a toothbrush but the dirt did not shift is there anything else i can use apart from brake cleaner?masterofinsanity wrote:nah whip it ou and give it a good polish up, just dont grip it with pliers or the vice as it will gouge it.
