Best approach for front calipers bleeding
Kevh1070
My Bike: Zxr 400 l3
Post by Kevh1070 »
Hi all, just stripped & rebuilt front & rear calipers on L3 model. What's the best approach on bleeding front set to get a decent result please as currently lever is like squeezing a jelly & frankly no bloody use
Any help greatly received, thanks in advance
CaNsA
My Bike: ZX6R F1
Re: Best approach for front calipers bleeding
Post by CaNsA »
Full left lock, this keeps the m/c raised and at an angle to get all the air out.
then pump until hard, keep lever pressed, loosen off nipple, tighten nipple.
rinse and repeat.
Kevh1070
My Bike: Zxr 400 l3
Post by Kevh1070 »
Thanks cansa, problem is this is how it was set up & tried for approx 1.5hrs in various approaches just its not responding in the least. Resivior is at dropping level at all thinking possible master cylinder fault
You need to use a vacuum bleeder, or reverse bleeding where you inject liquid from the nipple, into the calliper, up the line, past the MC into the reservoir
CaNsA
My Bike: ZX6R F1
Post by CaNsA »
I've never used a vacuum bleeder or reverse bleeding.
Never had a problem.
Miles
My Bike: ZXR 400 L3
Post by Miles »
Imo I've found that the traditional method works for most but a few have had to resort to vacuum bleeding.
I always had great results with the normal way but got a vacuum bleeder from Santa one year so have always just used it
Kevh1070
My Bike: Zxr 400 l3
Post by Kevh1070 »
Thanks all for the input, going to opt for the pressure bleeder & not beat around the bush with it.
