What are 'ceramic type' inserts in the pistons for?
Mine are crumbling and I cannot find any replacement inserts or complete with piston housing, are they needed as they stand slightly proud of the end of the metal part of the piston?
Piston 'ceramic type' Inserts
julesfay
- My Bike: Ninja Jules
Re: Piston 'ceramic type' Inserts
its not an insert per se, but a physical part of the piston.
you have two options, if available for the year of bike buy OEM from a kawasaki dealer, or buy the non-OEM ones off ebay/wemoto etc... they work perfectly fine and are easier to remove for repair as you can use standard brake piston pullers to remove them.
- Tirpitz
- My Bike: Kawasaki ZXR400L4
They are for heat dissipation. FWIW Kawasaki do not recommend using OEM sintered pads on pistons without a heat dissipating insert as it could lead to excessive brake squeal - so they say.
Hel braided hoses
Pirelli Diablos
Ohlins steering damper
A16 carbon fibre exhaust can
Nitron Sport shock
Hel braided hoses
Pirelli Diablos
Nitron Sport shock
