Are these the right one?!
mikey_m
My Bike: zxr 400 H1
Post by mikey_m »
Hi guys...
Ive took my rear break off today as it was seized up and not functioning at all...
The piston is nackered, and so are the seals. So, my question is, will this kit fit my rear break? - http://motorcycleproducts.co.uk/catalog ... 56407.html
My bike is a 1990 zxr 400 H1/H2 (not sure which!)
And info would be great!!
Re: Are these the right one?!
No thats for a front brake
Here you go rear caliper seal kit..................easy really
http://www.patternparts.net/?i=21609
mikey_m
My Bike: zxr 400 H1
Post by mikey_m »
If you really want to buy from that site you found here is the right seal kit.....................note price difference
http://motorcycleproducts.co.uk/catalog ... 56585.html
Like I said note price differnce the site I've linked to is cheaper
Just noticed the kit you've found includes a piston mine doesn't...................hence price difference
mikey_m
My Bike: zxr 400 H1
Post by mikey_m »
I noticed the price difference staight away!! but one link is only the seals, the other link is with both, piston and seals.
http://motorcycleproducts.co.uk/catalog ... 56584.html
Does this kit inluce both pistons to rebuild the back break? i cant be sure
Looks to me like it only has one piston and one set of seals.............................you'll need two
Better to ring them and ask..................have a look on wemoto....................might be cheaper
Personally I wouldn't use pattern stuff for my race bikes especially for brakes............................
mikey_m
My Bike: zxr 400 H1
Post by mikey_m »
thanks for the info lads.. .
So i would need two sets of the piston kit then? I just need to make sure im buying the right stuff. As they are very expensive!!
Im worried that if i buy a second hand caliper off ebay, that the pistons will be the same, seized.
Before you buy anything I'd take the pistons out and clean them up then I'd take the seals out carefully and clean out the groove that it sits in. And rebuild
Every siezed caliper I've seen is caused by corosion in the seal groove which builds up and forces the seal against the piston thus causing it to stop moving. And every one I've fixed has been a case of cleaning out the seal groove...............................with NO need of a new seal or piston.
Dremel and a wire brush fitting works wonders some emery cloth and a bit of elbow grease will sort it too
mikey_m
My Bike: zxr 400 H1
Post by mikey_m »
yes ok i will give that a try... one only problem, i cannot get the piston to come out!! And tips on this? bearing in mind that i have the caliper off.
Thanks guys.
mikey_m
My Bike: zxr 400 H1
Post by mikey_m »
Managed to get the pistons out of my front break today guys..
Take alook at the gunk inside them!!! literally clogging everything up!
Ive also cleaned the pistons and seals up so wont be needing new ones.
thanks for all the info !!
michael.
Without wanting to sound cheeky but good god man how on earth did you allow your brake caliper to get into such a sate ? ? ?
and that brake fluid looks looks like HP sauce...............its been in there for years????????????? Why ?
Top tip................ good brakes save lives............... look after em properly
And thats a front caliper ??????????????????? you said it was the rear one you had problems with ????
Frankly I think you should take it to someone who knows what they are doing..................
mikey_m
My Bike: zxr 400 H1
Post by mikey_m »
i bought this bike from a friend as a project.... Its been stood outside for along time!! hence the fluid looking like HP sauce, and which it did!
I would neva neglect my brakes, which is why im giving them a good clean! And yes, i did have problems with the rear brake, but that wasnt anywhere near as bad as the front ones.... Anyway, they are all in good working order now and feel really responsove, will take some pictures for you tomorrow.
Thanks, michael.
