that's what i did...RedexRobB wrote:id place the shaft of a spanner (oooer!) where the disk would normally go. Then use the brake lever/compressed air to push them out. There should be enough there to stop them coming out all the way then.
removing pistons from caliper
nc73
- My Bike: zxr400 L
Re: removing pistons from caliper
yep, they should come out most of the way then without popping out completely and allow you to pull them out.
nc73
- My Bike: zxr400 L
i have an idea..what about using a hose clamp that fits and use that to prevent damage while you wiggle it out??? i think that would work, gonna find out soon enough once i rebuild my fronts.RedexRobB wrote:yep, they should come out most of the way then without popping out completely and allow you to pull them out.
made a start on my 4 pots today, used the airline at work and "POP" out came one piston, the other 3 aint going anywhere!, have tried the grease gun method but the same none of them will shift!! NOW WHAT?? :smt013 the guy i bought these from had pushed all pistons on the 1 caliper all the way in
think i'm gonna have to connect it up to the brake lines and try and push them out.
- reds
- My Bike: ZXR 400
grease gun was only thing that even came close for me (got 2 of the 8 out with this method) even the hydrualic pressure form the brakes wasnt enough in the ned0- had to buy new ones !
well spent hours last night removed one of my 6 pots and put the 4 pot on, bled the brakes and out popped all the pistons eventually! they weren't that bad tbh so stripped and cleaned em all up and now i have 1 x 6 pot and 1 x 4 pot on the bike and the brakes are sh*t hot!!! gonna do the other side tonight
will#224
- My Bike: L1 racer
Was thinking about this again the other day, at work we have a hydraulic, jack, ram or puller set for putting coupling hubs on shafts and lifting various bigs items carefully. Its runs to 40,000psi and i reckon i could make an attachment to fit onto a brake line. Only problem is the mineral oil we use eats body fat. We did some heath and safety last week and they showed a pic of a line that split. A guys hand was just skin and bone after a few hours! EEeek!!!
I reckon the jacks that machine mart and the like sell might do it.
did a few more hours on mine today with the other 4 pot, managed to get the pistons out but buggered if they were gonna go back in so put the 6 pots back on, have bled, bled, bled and bled them and they are still naff. more bleeding tomorrow!!!!
Chris1984
- My Bike: zxr 400
Having a nightmare with mine,had them apart today as the brakes are sticking and 1 came out with ease but the rest are wedged in out of frustration i pulled one piston out with pliers and put a small scratch in it,will this now have to be replaced?
depends who you are asking? emery cloth, wet and dry, dremel, thats my philosophy then agian its your life you are talking about?
Chris1984
- My Bike: zxr 400
what could it do if i left it,what makes it so dangerous? Was just going to buy second hand caliper off ebay but they could be the same,might just but new pistons all round i no it will cost me but will give me piece of mind.masterofinsanity wrote:depends who you are asking? emery cloth, wet and dry, dremel, thats my philosophy then agian its your life you are talking about?
it might rip the seals and when you hit that brake you will just squeeze all your fluid out and the brakes wont work. (worse case scenario) i've seen some well gouged pistons in the past that have worked fine.not that i would reccomend it.
- My Bike: zxr 400
Dunno whether you have sorted the problem with the seized pistons, but diesel fuel is brilliant for unseizing just about anything, Wurth diesel injector cleaner works realy well also, don't no what effect either would have on the caliper seals though. Ive used both in the past on all sorts, seized injectors, exhaust bolts etc. If left overnight, seems to do the job, just a thought.
will#224
- My Bike: L1 racer
I did another set yesterday, i used paraffin, soaked them in it for a few hours, then pumped them with grease and used an airline. They came out easy.
Tried the grease trick - worked well but was left with one piston stuck in.
Pro's: It works
Con's: Messy work cleaning up afterwards
Tried the airline with a needle tip air blower that fitted into the bleed nipple hole - blew all pistons out no problems
On the other calliper two popped out and all I done was covered the holes with rags and gave it a blast and out popped the other two
By far the better option and I would say going to any garage/workshop with an airline and giving the fella a few quid to pop them out for you will save you a can of parts cleaner + the time washing the grease out of them.
With another set I used a piston remover tool as they were hollow and with a slight twisting action they came out no prob's too so another recommended way of getting them out if you have this type of piston.
Pro's: It works
