djb123456 wrote:Mori Man wrote:What's the span adjuster set at ?
i thinks its at 1. why would this affect it?
Because it makes the lever further away or closer to the bar to start with, so adjusting the available travel.
IME the front brake is a PITA to bleed properly. You will usually find microscopic bubbles trapped in the lines, splitter and also at the MC. You won't get these clear by the usual method of pumping with the brake lever. Your best bet is to get a vacuum bleeder to draw fluid through - that works.
Another way (but which takes longer) is to bang all the lines with a spanner to try and dislodge the bubbles. Leave the bike overnight with the bars turned so that the MC banjo is at the highest point so that the air can collect there (you will also probably already have some air trapped there which you wont dislodge). Then in the morning BEFORE TOUCHING THE BRAKE LEVER AT ALL crack open the MC banjo THEN pull the lever gently to push out the air. Tighten up before releasing the lever. Repeat as necessary. That generally clears it. You may need to repeat this once you've run the bike on the road as you may find some remaining bubbles collect at the MC banjo again.
IME Kwak front brakes take a lot of mucking about to bleed properly. Not difficult but takes patience.
If you want to rebuild the MC it's easy. Once the lever is off remove the rubber dust boot from the end of the MC piston and you will see a circlip in the recess. Remove and the MC piston pulls out. A rebuild kit will comprise new piston and seals (one of which you need to fit to the piston yourself), spring and new boot. Don't waste money on the OEM item, the pattern one from Wemoto is excellent quality and works A1. Replace in reverse order, fill system and bleed as above.
If you've got OEM rubber brake lines on and the bike is several years old and these have not been replaced the brakes will probably be spongy no matter what you do. Rubber lines have a service life. Replace with braided - they last for ever.
