hi guys
basically theres a weird noise coming from front of bike
like a hollow knocking noise. cant heard or feel it thru bars at speed but upto about 50mph i can
forks are fine, headstock fine
no movement when you shake forks
only thing i can think is wheel bearing or it occured to me today that maybe speedo drive needs greasing???
discs are new so not warped and the noise does not appear when front wheel in the air and wheel spun
so its got something to do with the weight of the bike on front wheel
any ideas?
front end knock
- Gemini
- cloning technology
front end knock
- My Bike: L1 racer
Re: front end knock
I had a motorcross bike that did that, turned out the bush in the forks was worn and allowed the fork to move slightly. I cant remember the exact name but it was the bush that sits on the stantion inside the fork and runs on the inside of the leg. It only happened on one and was the side that the bike was always leant on.
- Gemini
Re: front end knock
i forgot to mention that it dont make this knocking noise when at standstill and simply pushing down on forks
so im kinda doubting the fork bush scenario but thanks for advice
- Gemini
Re: front end knock
possibly pads knockin on discs but dont do it when u spin wheel in the air
- Wabby
- My Bike: ZXR400
Re: front end knock
I had same thing.
Greased the old speedo drive, and now she is silent (Until Speedo drive snapped, lol)
- Gemini
Re: front end knock
had a suspision maybe speedo
thanks
thanks
- Gemini
Re: front end knock
*** update ***
the knocking noise was due to a fecked wheel bearing
job done
job done
