Hi guys,
Could anyone please measure up the dimensions of an L model front Axle for me, I haven't got mine to hand and I need the dimension in order to make up some spacers for my zx6r forks to take the 400 axle, I need the following sizes if possible:
Length (a) =The total length of the axle when tightened up
Length (b) = The OD of the thicker portion at the end
Length (c) = The OD of the lip
Length (d) = The depth of the lip
Length (e) = The Length of the end thicker portion
If you can be accurate to 0.05mm it would be great, dont want a loose axle flapping around in my wheels!
Front axle Dimensions
- My Bike: ZXR 400 L2
Re: Front axle Dimensions
So heres what I have got so far, Obviously the central whole is not the right size at the moment but once I know the measurements I can machine it to the right dimensions to take the 400 axle
Also made up some 5mm spacers for the calipers so my 310mm disks will fit
Someone must have an axle laying about?
- Miles
- My Bike: ZXR 400 L3
Im taking my front wheel off later, I'll dig the vernier calipers out and measure up
thats great cheers matey!
