Awful Sound Coming From The Rear
- mikeee
- My Bike: ZXR400 L9 (1999)
Hi Guys, Im Michael.
I just had my tyres replaced (Bridgestone BT-023's), well 2 days ago, and I've noticed this awful grating sound coming from the rear wheel, or near the wheel, and i can't think for the life of me what it could be, i did think that it could be that when they put the rear wheel back on the torqued the spindle to much and crushed the rear wheel bearings, but that just seems a bit drastic, so my next thought was the cush drive rubbers, thinking that they had worn but then again i don't think it would make the sort of grating sound that it does, plus it didn't do it before i got the tyres changed. so basically i really don't know, and i can best describe it as a grating hmmmming sound. any ideas??
Michael
Michael
Renegade Exhaust
Carbon Fibre Fork Preload Adjusters
Wezmoto Braided Hoses
Black Short Levers
Black Double Bubble
Renegade Exhaust
Black Short Levers
Black Double Bubble
- CaNsA
- My Bike: ZX6R F1
Re: Awful Sound Coming From The Rear
Before you pull the wheel off to check it out...
How tight is the chain? Is the wheel aligned? is it disc rubbing on the pads?
- mikeee
Thanks For the reply, i checked the chain, they tightened it nicely for me, so i don't think its that, and im not quite sure on the pads, what i mean when i say this is that if it were the pads scrapping on the disc, would it not be a more brushing sound? and constant, where as the sound im getting is a intermittent rough grating one every time the wheel rotates i get it.
Michael
Michael
Renegade Exhaust
Black Short Levers
Black Double Bubble
Renegade Exhaust
Black Short Levers
Black Double Bubble
- mikeee
Forgot to mention that the wheel is aligned yes. :/
Renegade Exhaust
Black Short Levers
Black Double Bubble
Renegade Exhaust
Black Short Levers
Black Double Bubble
mmmmmmmmmmmmmm no noise...............wheel comes out new tyre on wheel goes in................theres a noise
Not exactly difficult to figure out is it ?
- mikeee
well, personally i can't, i know its not the fact that there is tread on the tyre, because this is a horrible noise :/
Renegade Exhaust
Black Short Levers
Black Double Bubble
Renegade Exhaust
Black Short Levers
Black Double Bubble
Are you serious ?
- mikeee
Look Cargo, i posted just to see if anyone could help, maybe it was a bit of a stupid question to you, but to me it wasnt, quite frankly if you didn't want to help, you didn't have to reply, and i know your an experienced and valued member of this forum, but seriously you seem to just be blunt and rude to the newer, and less experienced on this forum. and yes im one of those less experienced, im 17 and this is my first big bike, and i like to know that if i have a question that it might be answered in a polite manor, is that to much to ask for? no doubt you will delete this post but owell what can i do :/
Michael
Michael
Renegade Exhaust
Black Short Levers
Black Double Bubble
Renegade Exhaust
Black Short Levers
Black Double Bubble
- CaNsA
- My Bike: ZX6R F1
Pack it in mikeee.
Take the wheel off, check the bearings.
- mikeee
Alright, thanks, ill do it in the morning.
Sorry was just putting my point of view across.
Renegade Exhaust
Black Short Levers
Black Double Bubble
Renegade Exhaust
Black Short Levers
Black Double Bubble
Believe me I'm more than happy to help you but I cant help someone who either cant or doesn't want to help himself.
Your bike was fine no strange noises
The wheel was removed
a new tyre was fitted
and the wheel was replaced back into the bike
now your bike makes a funny noise
Now how hard is it to figure out that the noise is very likely to have something to do with the removal and subsquent replacement of the wheel
I would say the average 17 year old should be able to realise that and take action to investigate
This is the bit when you have to help yourself
Enjoy
Enjoy
- mikeee
I do understand that it more than likely something to do with the removal and subsquent replacement of the wheel. but i thought i'd ask anyway. Of course i wanna help my self, im more than happy to get stuck in!
okay well, ill check it out tomorrow.
thanks for the help
thanks for the help
Renegade Exhaust
Black Short Levers
Black Double Bubble
Renegade Exhaust
Black Short Levers
Black Double Bubble
- Tirpitz
- My Bike: Kawasaki ZXR400L4
You say the garage 'tightened your chain up nicely for me'. What exactly do you mean by tight? Your chain should not be 'tight' it should have slack in it and if it doesn't when the tight spots run round it will make a bad sound. You will also fubar your gearbox output bearing running it like this. And the chain and sprockets.
My experience of a lot of garages is that they have no idea about correctly tensioning a chain and take all the slack out of it. I only give the imbeciles loose wheels
Anyway, you should have enough slack in the chain at the tightest spot that you can push the lower run upwards and with moderate pressure it should stop just before touching the rubber cover which goes round the swingarm near the gearbox output sprocket. You will need the bike on the ground while doing this, NOT on a paddock stand, the normal weight must be on the front / rear wheels. Move the bike around to find the tightest spot in the chain - then do this test with it at that position. If it is tighter than this it is too tight and you need to loosen the adjusters / wheel spindle and get some slack in the chain.
A very tight chain will produce horrible grating sounds like you describe.
Hel braided hoses
Pirelli Diablos
Ohlins steering damper
A16 carbon fibre exhaust can
Nitron Sport shock
Hel braided hoses
Pirelli Diablos
Nitron Sport shock
- mikeee
Got around to taking the wheel off, and it seems that my rear sprocket is bent inwards, dunno how it happened, so i rang the garage and they have offered to fit me a new chain and sprocket set free of charge, as i argued that the sprocket was most definitely not bent before i took it there.
Thanks for the help
Michael
Thanks for the help
Michael
Renegade Exhaust
Black Short Levers
Black Double Bubble
Renegade Exhaust
Black Short Levers
Black Double Bubble
You need to discover why the sprocket bent........................bending a sprocket is not an easy thing to do.
Like did some magic sprocket bending pixie do it ?
Long shot here............................is the spacer between the sprocket carrier and the wheel still there? and is it the right way round ?
Are the wheel spacers there and the right way round ?
photos would help
photos would help
