Am I correct in thinking that a zxr400L model front wheel is the same as the zxr750L front, had a look on a few microfiches and it appers they are with all the attachments being the same number, discs appear the same as well, only difference I can spot is a different numbered bearing
Rob
Front wheel
zxrob
- My Bike: zxr400, zxr750,, zx9r
Re: Front wheel
Not entirely sure - spoke pattern might be slightly different.
I know on my zrx that a 1100 front wheel goes in as well as ZZR400 / 600 - they just look different.
MM!
MM!
zxrob
Re: Front wheel
Cheers MateMori Man wrote:Not entirely sure - spoke pattern might be slightly different.
MM!
btw, are H model wheels the same (front and rear) as the L model
Rob
Re: Front wheel
Rear is different for sure- different axle size.
Front - I have used a H wheel on L forks so guess they are interchangeable.
